Got mine 2 days ago in Stonewash. I had it on order for over 18 months. The finish is great as always and it's beefy as hell. I really like the blade sharp on this one, the point is a needle, absolute needle.
You guys should watch this:
[video=youtube;woG2l1FWI3Q]http://www.youtube.com/watch?v=woG2l1FWI3Q[/video]
How center it is depends on how you are assembling the knife. You need to make sure you are applying all screws SIMULTANEOUSLY, and tightening the pivot last.
If you tighten one side of screws, then the other, the blade will be off center.
Update: I forced the detent bar over on the stainless steel liner and it pushed the blade back to the center a bit. It is not perfectly centered but it is not rubbing the stainless liner anymore so I am happy.
,There's a nifty trick out there for centering Emersons. There are some YouTube videos. Basically crank the pivot all the way down, loosen the body screws all up, then wedge a piece of folded paper between the blade and the side it is off center towards (forcing it all the way in the other direction) then tighten the body screws up, remove the wedge, and loosen the pivot to your preference.
