Originally posted by Investigator168
RL:
You seem to know a lot about knives and your explaination was both simple and clear!
Wow, thanks for the compliment...I always thought of myself as a beginner!
My comments about the MOD relate to the
design such as the fact that you can use it as an impact weapon in any direction (including Gunting-like strikes with the top of the closed blade) and you can hold it in ANY grip (including Filipino, reverse grip-blade in, reverse grip blade-out) etc. etc. (hey, I don't want to give it all away
I don't have any experience with the AR/GR but I have read the same things that you did...namely that it is a very tough knife. Incidentally, you should read the thread about flicking on the Strider forum...they say it shouldn't be a problem and they will simply replace the stop pin for you if anything goes wrong (something to consider!).
If you are interested in "mega" (or "beefy") folders and you don't mind paying for customs, you might want to look at Farid's work with his diamond-coated tungsten carbide blades (edge hardness of 80+RC!!!) or Jeff Hall's Bounty Hunters. I'm considering the Laci Szabo RAD (7" blade, 4" handle) even though there are certain design issues (e.g. the massive, heavy blade creates a lot of stress on the lock).
BTW, Jim's comments are scary! I will really try to limit myself to one THWACK per day
RL
