Square_peg
- Feb 1, 2012
....and hammer the weld while its still hot.
To work harden it?
To work harden it?
Interesting advice so far.
If I weld it, I will let it cool without pounding on it. I will then grind everything flush, including thickening up the edge just a tiny bit, and then normalize 3 times, likely at descending heats of about 1600F, then 1550, then 1500. I will also soak at these temperatures a bit longer than usual in hopes that carbon diffusion will largely draw carbon from the high/medium carbon original axe head into the low carbon weld thereby equalizing the carbon content throughout. (BTW, does anyone have any information on what steel Collins used for the Legitimus line?)
For rehardening I will soak again, a bit lower at 1475 or so for about 5 minutes, then quench into Parks 50. I am considering just fully hardening the entire head, rather than just edge quenching the bit. At the thicknesses of this piece, neither the entire edge nor poll will fully harden, but they will be a lot stronger than just steel that has been heated and cooled. And, when tempered around 500-550F everything will be plenty tough. (I'll begin the tempering at 500 and decide how far to go based on how the edge works with a file.)
