- Oct 18, 2001
"Snoopy" sent me his cracked dhankuta kothimoda (which Bill replaced a la H.I.'s warranty). Little did he know what I had in mind for it....
Good lookin' little knife with a beautiful handle. Shame I had to break it.....
But I've always wanted to "peek inside" a khukuri to examine its grain structure. Unfortunately I don't have anything to compare it to at the moment....but that will come soon I hope.
Anyway, in the meantime...enjoy some pics and ponder what you see.
Here is a pic of the knife after I broke it. I don't have a "before" pic (I think David does - do a search if you're curious). The red arrow indicates where where the crack began - and ran to the spine. The crack that I put in it goes from the arrow to the edge.
Here's how it went down:
I chopped completely through a 2x4 - no visible damage. Take that all ye small-khuk-can't-be-choppers nay-sayers.....!
Went through the 2x4 again.
One more time just for kicks.
No damage....no movement....nothing.
I figured, I was going to have to submit it to some "Cliff Stamp" level tests....so I picked up a big piece of cherry and used it to baton the knife halfway into a 2x4. Nothing. 3 more times.....nothing.
Ok, losing patience....
So, for the heck-of-it...I put the tip into my vice and tried to pull/bend it. Wouldn't budge...started eating up my vice. I got the piece of cherry and beat on it. Then I got the hammer out (for sure this would work, I figured) and hammered it with a thin piece of cherry to keep from marring the face.
Best I got was a nice vibration in the handle....
Lil' brat....
I took it out of the vice, laid it at a 45 degree angle on the floor and whacked it bare with the hammer.
Ting!
Finally. Of course, this last test has no practical application to real world chopping....but I had run out of ideas.....
Anyway, once I had it cracked, I could now take some zoomed in pics of the blade structure.
Here's a pic of the knife end of the break:
You can see how the "previously cracked" part is darker than the rest. My theory on this is that the crack came in the forging. Somehow there was a flaw in the steel that caused the crack or delamination, etc. Then under quench and heat-treat, the crack expanded and filled with scale - which is the dark stuff you see.
Pic of the tip end of the same break:
Here's a closeup of the transition (on the broken tip end). Also shows the grain size. Looks even - no "striping" or "banding" - which would indicate an uneven temper.
Another pic showing the tip - again on the tip end. Clean, even grain structure.
Lil' brat....
Ting!
