Horsewright
- Oct 4, 2011
Stacy ... i am extremely confused. IIRC, there has been a LOT of discussion around peening pins to create a mechanical hindrance to separation of the scales from tang. Horsewright, (man .. you are omnipotent...my god...., BUT...) you have posted videos of peening pins on bolsters. Am I reading too fast and missing something.... or have I always missed something, and are you both now saying don’t peen pins on scales?
I can't remember who it was, but IIRC, one of the big time old guys used to leave the pins 1/16" proud and give them a little squish with a cheap 1 ton arbor press. He said it didn't take much to expand the pins.
That said, I agree with Horsewright.
When I use pins and not Corby bolts, I just drill the holes for a smooth slip fit and don't peen. I use good epoxy and grind a reservoir in the tang (and usually some through holes), then make sure epoxy is down every pin hole. As long as a tiny bit of epoxy gets down the hole, and the tang is properly bonder to the scales, the pins are mainly to prevent any shearing force.
Yep, peen on the bolsters but not on the handle. And as we've discussed before I peen mosaic pins (bolsters) all the time, even though folks say ya can't. But I don't peen handle pins. No need.
Bolster pins all peened. Handle pins not.
