- Feb 17, 2007
I have an order from a couple brothers for 2 D2 sharp finger style knives and 2 of my D2 drop points. Because these sell well and things happen I started out with 3 blanks of each. Good plan because after finishing the drop points to the point of being ready for scales I was working on the sharp fingers and one of them had a "scratch" running down from the spine that wasn't coming out even when I went back to 220. Finally I took it back over the the grinder with a A65 belt and it didn't go away then either. Something about the scratch had said crack even before I went to the grinder. I took it to a vise and clamped it with some hardwood pads by the scratch and pulled on it with a bit of force. Snap. Sure enough it was a crack. The steel was maybe 1/8" thick at this point. The crack was a light brown and about 1/2 way (1/16") through the steel and about 3/8" down the blade and made a semi jagged triangle. The rest of the steel was good with real fine grain. This is Bohler K110 D2 and I have a lot of it and never had a problem like this with it. I am glad I saw it and broke it and the knife never left the shop.
The brown color has me thinking the problem have been some kind of an inclusion in the steel? There is also a tiny spot of the brown slightly away from the main part. Really has me wondering.
Standard heat treat. 1500 soak then 1850 for 40 minutes then quench between cold aluminum plates, then dry ice slurry followed by 2 tempers at 425. All came out straight and none needed any straightening. The other 5 knives seem fine, sanded out and polished up well.
