Where did you purchase the knife?
Just a side remark: the blue ano of the thumb stud looks pretty worn off. Did you buy a used Sebenza? If yes, how can you be sure that this issue is caused by CRK? If no, please ignore my comment.
BladwHQ shipped to you? I had difficulty getting them to ship here (although they were very gracious).
In looking at that first picture it looks like the scales are not completely seated with the body screw/spacer?
A pinched washer will give an off center blade like in the one pic you posted. I know there is no way in hell that left the CRK shop that way.
CRK will not send washers out as each are hand fit to each individual knife. 1/1000" will make a difference. This is the same with lockup%. Watch the BHQ video or the Exquiste Blade video. It Will give you a better understanding of what goes into each knife.
By sanding the washers, you did more harm than good. Now the tolerances will not be as tight and issues can result. Looks like there was simply a pinched washer and you jumped the gun. Washers can be easily pinched, even by a veteran...........I just sent a small 21 in for a spa as the previous owner badly pinched the washer. I cleaned it up and it functioned fine, but I know it wasn't right, so off it went along with another that I have been meaning to send in for 10 years now.
What is meant by a pinched washer?
When you disassemble the knife and take it apart for cleaning and in doing so, you use your index finger and thumb to hold the washer for cleaning, it's pinching the washer
Or, upon assembly, a washer gets out of place unknowingly and gets pinched between the bushing/blade and deforms the washer.
Photo #2 looks more like an assembly issue.... if not, back it goes!
