If you use loctite be sure it's the blue and not the red. If you every need to make an adjustment you can remove the screw with the blue loctite but the red is permanment. Clean the screw threads and the female threads with alcohol on a pipe cleaner and ad the loctite and tighten . After setting overnight it should stay put until you want to remove the screw. The same goes for the fingernail polish.
I once used the red loctite and I could never get the screw to loosen. If you you want it to be permanent use the red.
