I've played with this thing for the last 20-25 minutes
and I have a conclusion already. I'm going to use my 5 point system
1= Poor. Go to bed without supper
2= Fair. Eat you supper, but no dessert
3= Decent. Not too bad, but you need to eat all the veggies
4= Nice. You can have your cake and eat it too
5= Awesome. We're goin' to Sizzler!
Sharpness.
Out of the box, it's like a straight razor. Sharp as all get out.
Keep in mind this is a single sided knife.
After opening it approximately 50 times it has remained very sharp.
It kinda creates micro serrations on the edge after 20 or 30 openings
I've made over 200 cuts into copy paper, hard plastic retail
packaging, cardboard, some carrots(yes, I cleaned it first)
The blade seems a little soft and as I didn't cut anything
harder than carrots with it, it gets a point for now.
But wood, accidentally striking something hard, may cause problems.
+1 Point
Ease of use.
There is a Torx T-10 screw for the pivot. I played
with it for a few minutes to try and adjust tension
of the blade. No use. If you loosen it at all
you get blade wobble when fully open.
It has a Spyderesk knockoff oval thumb cutout
that is still hard to use because the knife is
hard to flick out with just your thumb.
There isn't a lock mechanism on this knife. Just tension/slipjoint lock.
So if you lift the knife while cutting into something heavy
it could possibly fold up on your fingers.
The instructions with the knife actually state this.
I quote, "Don't push down when removing the Edgie from a cut.
The blade may fold accidentally." ouch
-1 Point
Wear and tear.
When closing you actually have to push the blade
down into the handle to make full contact with the gritbar(my made up word)
The gritbar has some wear on it and looks like it would only last
a few months under normal use. 1-3 times a day??
CRKT calls it a '400 grit diamond-coated strip'
I call it 'not gonna last long enough to keep the blade sharp'
The sheet also states "intended for light-and medium-duty tasks"
-1 Point
Look and feel.
Very comfortable to hold. Good textured rubber grip
Nice ergonomics. Has a bit of weight to it. Not as
heavy as my SS Endura but beefy. Stainless liners are the reason
Kinda reminds me of a Spyderco Rescue though (without serrations)
+1 Point
Price
This thing only retails for $29.95
So, you could probably pick one up for $19-29??
+1 Point
Well, that's 1 point. Not too good.
But, if you're cutting open boxes and doing some
easy work with it, then yes it would be fine for that.
But remember, for around $50 or so you could get a Delica
that would last much longer.
Personally, I would not buy this knife.
mike
