- Jan 29, 2014
That is awesome - nicely done!
FourtyTwoBlades would have to say it for sure, but the grain seems clear to me.I think that many of the lines that you are seeing may be rough marks from rasping.
Theoretical in what sense? That it probably will not end up breaking?I think it's kind of a theoretical argument on a handle this size.
Between the short length, diameter, and how hard it will be swung I can't see breakage being an issue at all.
Looks nice to use, which was probly the primary goal anyway.
In the short term as a direct consequence of the grain, chances are you are right.
But as improbable that the handle ends up breaking right away is, another consequence of the exposed ends is more rapid decay and wear that weaken the wood over the long term. Have a look at your old double bitted and how the shoulders are rough on the under side and they are often cracked if not split there. It comes from the exposed end grain where first of all moisture comes in followed by bacteria and decay which break down the wood and weaken it over time. So it's really a long term question, or as you might say issue.
There seems to be, what I regard to a healthy fixation on grain character in handles around here. What's puzzling me in this instance is why this concern is being tossed aside and the attitude, "whatever works" now taking hold. Any one can help me out here?
What’s the “normal” sequence installing cross wedges. Main wedge first,then cross wedges? Cross wedges first? All together?
The curves are present to align the handle with the head's center of gravity.
Ive had good luck the last three times with solidly seating the crosswedge first, notching it with a small wood chisel/knife, cutting it off, and then driving the main wedge. Once the main wedge wont go any farther, I cut it off almost even with the crosswedge, and then drive the two of them together. Seems to work so far.
COTS does a great job of explaining and amazing application of the crosswedge:
http://www.bladeforums.com/forums/showthread.php/1233816-COTS-Project-Thread/page10
Which will increase accuracy by some varying degree. It's a sensible design and well orchestrated. Overall a little heavy for me for a one-handed axe but I don't doubt it will find use.
I saw and even commented on your video. The physics of the design on paper, the theory of balance and distribution, all that set aside, (because this isn't an argument I've engaged in at all), your and your fellow believers', confidence in the actual handle comes down to faith up until now, a hope that it will be just fine because it looks sufficient. In any case that's the defense of the handle that has been provided so far. You certainly don't have to prove it to anyone as long as you agree that it is hope forming the basis for your justification. Either you hope and believe and have faith in the handle or you provide some rational explanation. Unless there is some engagement on equal footing the discussions go on and on side-by-side but no conclusions are possible. Well, other than, "you do what you want and I'll do what I want".Did you not see the video of it being deliberately subjected to repeated shock? This handle is fine. If you don't like it, make yours differently.![]()
"The handle is sufficient"
"Ok, how can we know it"?
"Believe me, it's enough, others say so as well".
"Ok, but why is it sufficient"?
"Believe me, it's hickory, it's sufficient".
This is a perfect example of what an axe handle (whether straight or curved) with vertical end grain (when spying the eye or butt) shouldn't look like when viewed from above (ie aerial or plan view). Most of the handle breaks I've inspected during the past 40 years are the result of 'runout' such as is depicted here. Runout on a elevation view (viewing from the side) is unavoidable when horizontal grain wood is used to make a curved handle. Forum member quinton on the other hand (having grown to appreciate the extra flex (namely shock absorbing properties) of horizontal grain handles exclusively uses riven and air-dried Hickory. Something the majority of us are not able to select for at a handle supplier, hardware store or lumber yard.Run out is where the wood ends.
