".....Also, I didn't want/need to sand after heat treat. It's just not too difficult, so I'm cleaning up the surfaces of a couple that could use some closer attention.
If you want knives that look and cut good, you always need to sand after HT. Regardless of the HT method, there is a thin layer that needs to be removed. If you merely want a knife that cuts so-so, you could not do anything but put an edge on. If you want a knife that cuts good, you need to sand the bevels to make the edge thinner than it was at HT.
I'm very sorry for the miscommunication! Of course, sanding is required to remove the heat treat scale and thinning the edge. I should have said that I didn't want/need to sand , but I assumed it was understood.
Thank you!
