This kinda gets to the nub of the issue... research is necessary and useful, but ultimately we must get the researchers to translate their findings into useable, actionable information and then on and into products with noticeable performance improvements.Originally posted by Ed Severson
The Eta carbide debate comes from the lack of conclusion as to what actually helps the steels, getting rid of retained austenite or precipating extremely small volumes of carbide that are so small you need an electron microscope to find them.
You have over-generalized. Only some of the supposed benefits of cryo, from literature, are in question. And the benefits must be kept in context of usage (e.g. precision tooling vs. improving knife blades).Originally posted by V Shrake
But if Busse *does* use cryo as part of their tempering process, it sure would exlain why Cliff is so high on the stuff, despite being proven wrong about its supposed benefits.
Cryo. has been around for many years, But there is still alot to learn about it. Keep on testing and good luck. Paul.
if Busse *does* use cryo as part of their tempering process ...
Mete & EdAccurate Plating said:Ceraguard is the newest Accurate Plating and Weaponry Firearm Coating offering excellent corrosion protection, outstanding abrasion resistance, hardness and durability…
The 'H series two component ceramic hybrid Gun Coatings were designed to provide a high quality, long lasting finish. After a full cure they have excellent resistance to most solvents and chemicals. At Accurate we oven cure the parts for maximum durability.
That's "WEAR" the similarity ends. Tests have shown almost a 60% gain in wear resistance according to tests by an independent lab...
