Yes, fantastic real test review...which influenced me to buy one. I have no doubt the knife can hold up to the kind of abuse seen in the video. But...over time, those springs will break. Benchmade makes great knives and I own several. This is one I can’t recommend until they figure something out with the springs.Well worth watching all of this !![]()
It definitely is. Very similar in terms of size and how it feels in hand. More so than the 4max.I'd think that the Cold Steel SR1 is more comparable than the 4 max.
I agree . I don't like the Axis lock for the extreme hard use role . I was just surprised how well it did in the video . I don't think he's done the 4 Max ?Yes, fantastic real test review...which influenced me to buy one. I have no doubt the knife can hold up to the kind of abuse seen in the video. But...over time, those springs will break. Benchmade makes great knives and I own several. This is one I can’t recommend until they figure something out with the springs.
I think for hard use applications, the SR1 or Recon 1 are both preferable too in that the scales provide good traction. The 4Max feels great, but the slippery scales concern me.I'd think that the Cold Steel SR1 is more comparable than the 4 max.
I agree. Almost 10 oz weight for a folder is more knife than I have ever needed for a pocket carry knife.I've had several BM 0275 folders, and they are great knives. The 0375 is also fine at a hair over five ounces.
The Cold Steel is a beast..0.180" compared with 0.170" (BM), and either one is capable of tearing down a high-rise building, if you're in the mood.
But 9+ounces on the CS compared with 5+ounces on the BM is NOT a good selling point (for me), even though the Cold Steel blade-steel is much better on most counts than the D2.
Just a note on the Axis lock springs:
Whilst I appreciate that this does not necessarily apply to those posting on this thread, the best way to break an omega spring is by disengaging the Axis lock by using pressure on only one side. After a while one of the springs will break. I’ve got half a dozen Axis BM’s, including an Adamas, but no broken springs as yet.
That’s strange, because Benchmade themselves have said it in the past. I believe it may even be on this website somewhere.I only have three Benchmades (one of them is an Adamas), and carry them frequently with no spring breakage. I do not follow your advice. The Benchmade representative here on the forum does not even advocate this.
Well found.l found the quote from the Benchmade Design Engineer https://www.bladeforums.com/threads/question-for-jimmy-concerning-omega-springs.1511257/page-2
"If you apply pressure to one side of the axis bar (lock stud) you will need to pull that side down a little farther than necessary to disengage the lock. This could result in slightly higher stress on the side that is being pulled and slightly less stress on the opposing side. Realistically though the difference is minuscule especially if you compare to using both fingers and pulling the lock stud all the way to the rear every time. In other words it doesn't really matter."
