It is probably to do with the lock moving in to a new spot that needs polished out with a few cycles. Same type of thing happens with liner-locks if you use it on a really good, hard session or snap out the blade playing around with it a bunch of times. If you waved it open several times it might have instigated it.
I don't agree with CS lockbacks or Tri-AD folders not being good, have used them a ton in past 16 years. A good squeeze on the lockbar and slight pressure on the back of the blade with other hand should make it come out - then do it again a few times to smooth out it's new home, loosen pivot if needed/make it easier like mentioned above.
