Hello, I have a Cold Steel Recon 1 with a Clip-Point blade, coating removed from the blade and lock-bar. The blade is very scratched up because I used sandpaper to take the coating off, but since it's a stonewash finish that means you can use a high-grit sandpaper to remove them if they really bother you. Also if you put negative force on the blade you can feel a bit of wiggle in the lock, but it came this way from the factory so I'm assuming the tri-ad lock may need to sink in or something. And since there's no play with positive force, that means it won't really affect cutting at all (and it hasn't). I also sanded a section of the handle under the pocket clip, so it doesn't rip your pocket up so much when you use it. Also there's a slight scuff on the spine of the handle as you can see in one of the pictures.
What I'd like for this knife would perhaps be another CS knife, but I'd be happy to look at anything you have. Here's what I'm sorta looking for in specific:
Cold Steel Ak-47
Cold Steel Recon 1 (Tanto)
Now I also have a Cold Steel Voyager, large size, in vaquero blade. Lightly used, pretty much no signs of wear I can pick up. Like the Recon 1 there is slight wiggle in the blade if you try to feel for it hard, but again, it came this way from the factory, not from use. Also like the Recon 1 I sanded down the part of the handle under the pocket clip so it doesn't rip the pocket up while being used. Now for this I kinda wanted to trade it for another Voyager, same size but different blade style, Clip-Point or Tanto.
But again, I'm willing to look at anything you want to trade. And if you have any questions or want specific pictures on these, go ahead and ask. Email me at Twisted4000@yahoo.com.
Cold Steel Ak-47
