HighwaterKnives
- Jun 25, 2024
Working on a high alloy cu mai and looking for some help getting things to stick. Target for the outer layers is aeb-l with a target of the core k390 or v10. I know I'm asking for a lot. .010" copper thickness
Coupons 1" square of a varying alloys with a single layer of copper. All is cleaned with acetone after sanding to 100 grit with a fresh belt and Tig welded around the full perimeter.
Using a heat treat oven set to temps below I am rolling the coupons .005" per pass for around 5 passes
So far my experiments.
304 stainless-52100 1925f- not sticking to 52100
Aeb-l - 15n20 1800f -15n20 sticks better, aeb-l separated when bent 30 degrees.
K390-aebl 1950f and 1800f samples k390 cracked, oxidized, copper fused poorly
Is 1800f too high. Is there something I should be doing as far as prep, temp, number of passes to get this to stick better? Mig instead of tig? Flux?
