- Nov 10, 2011
I have used the Blaze 120 just recently. The cut well but I burned one out on hardened 20CV pretty quick. I suspect that with the wide variety of grinders out there that results will vary, widely.
Scott, I had bought about 10 of the 220 grit norton blue fire belts that are zirconia. If I recall, they became my go to belt for finishing around the tang and spine. They heat up too much finishing the bevels on a really thin blade after just a couple passes for me. I grind free hand with my fingers on the blade so I can feel the heat as it comes on.
yeah, i think grinder speed makes a big difference in performance. I found that grits finer than 100 need to run at 600FPM or less and/or be wet if you want any life. I like the Norton bluefire 220 and the 3M 707E for finishing, i run them wet at 200 to 300 fpm.
scott
