Welcome Bladesmithh. Fill out your profile so we know a bit about you and where you live.
I went by "Bladsmth" and then "Bladesmith" for many years before switching to my real name.
Forget the angle. It will just cause you pain. Do as suggested and scribe/draw a centerline and grind/file up to it in steps. I heavily recommen filing the bevels for a beginner.
Don't do any one bevel all at once. Do each halfway, then each 3/4, 7/8, etc. until just before they meet in the center. From there go to finer files of grits. When going to hand sanding a stiff backing block (aluminum or hardwood) is a necessity. Coating the blade with a black marker or blue Dykem (best choice) is a wise decision to help you when grinding/filing bevels. If all goes well the final line will be straight and centered and the tip will still be in the middle. Don't panic if it doesn't happen that way. Adjust as needed to even it out and quit when it is as close as you can get it.
