Curved Lockbar Cutout
Hi Guys,
So far I have been cutting my lockbars with either a cutoff wheel or a thin slitting saw. It has worked very well but I wanted to add some curvature to the lockbar cutout shape. I know some of the makers do it with cnc and a small end mill. I only have a manual mill and very basic machining knowledge & skill, not enough to do curves manually. Is there any other way to get the curvature besides cnc? Thanks for all the help!
Most countoured lockbars are cut by waterjet when the makers have the liners/frames cut. There are a few who do it with tiny endmills in a CNC mill and there are some that are done by EDM. You will drive yourself crazy breaking endmills if you try to cut them manually but, if you have a ton of patience, you could use a rotary table to cut curved lockbars on the mill. I know others have said it doesn't work well but, a scroll saw might be another option; I've not tried it. You would need carbide blades for Ti on a scroll saw.
Bob
Bob
Thanks Bob, that is what I suspected. I'm doing everything by hand, including cutting the blanks on the bandsaw. I won't be waterjetting, edm or cnc, nothing wrong with it, just not my thing.
If you have the patience and the skill, there's always the trusty old jeweler's saw. (Disclaimer: I tried it and I had neither the patience nor the skill).
The jeweler's saw...that's the best option for a clean work. Be prepared to break some blades at the beginning, have some spare :)
