- Oct 7, 1998
Cliff Stamp said:This is worse with many of the high carbon steels, I have done salt water soak tests on ATS-34 vs 1095 for example and ATS-34 looks much worse with greater pitting.
Which steels specifically and how were they heat treated and to what angles were they sharpened? Do you really think his results apply to blades custom hardened to the protocols described in the above?
As for a warrenty against rust, it isn't like the high carbon stainless blades are immune to this either, I don't dip my slipjoints in oil either. In fact I stopped oiling my knives, carbon and stainless a long time ago.
-Cliff
Cliff I didn't write the book. You brought up the meat cutting thing; I pointed out a published report with much different results than those to which you alluded. If you have questions about Mr. Juranitch's book, you'll have to direct them to him.
I have never ever made a folder with a stainless blade which has developed a rust problem. But you are correct, stainless steel is not "immune" to corrosion problems. I don't know of anyone who has claimed it was. It is much, much more resistant to rusting than normal carbon steel, hence the moniker: stainless steel.
Brownshoe: How can I be any clearer? I have stated repeatedly in this thread that slip joint folders tolerate rust mechanically MUCH BETTER than liner locking folders. They still look rusty, but they open and close. What are you not understanding about this?
The original poster asked about a Sebenza which is a tactical, framelocking folder. I attempted to provide an answer to his question in my first post.
I use Damasteel powder metal damascus in my folders, which is very stainless. For information about this steel, contact www.damasteel.se.
Steelhead: As far as I know there is no way to make a folder with an insert as you suggest.
Some people have almost no problems with knives rusting and others do. As I have said above, folders give the most worry in the pivot area, which is why I am trying the TiAlN coating. This is much harder than the bronze bushing and washers and also also fairly slippery to help reduce the need for other lubrication. I am anxious to see how well it inhibits rust. If you want a folder with a carbon steel blade, check my website, I can certainly make you one. I don't know if I am allowed to give my URL, but if you google my name, you will find my site. I think M2 HSS makes a super cutting knife.
