- Feb 17, 2009
Big thanks and credit to Brian Fellhoelter on how to make a custom size etching machine hand marker. He posted how to make one on Knifedogs so I decided to make a couple and share it here.
I made this from a carbon block. You can use a motor brush as well. Here is the list of things to make it.
Carbon Block $7 from Ebay. It can be used to make several heads
10-24 3" Stainlesss bolt, washer and nut
Wood dowel
The carbon block was to size, drilled and tapped. I cut 2 blocks one for each size of stencil for my logo.
Drilled a hole into a wood dowel for a handle and wrapped it in electric tape.
Assemble it together and use a rubber band to hold on the felt. The felt comes from Michael s and is cut to size.
Attach to the etching machine and it makes a nice mark with the custom size hand markers for your stencils.
Total cost is less then $4 each hand marker.
This gives you the freedom to make any size head you want. Really does a great job and a big improvement for those who are making their own machines or are using Q tips for marking.
Wood dowel
