Another trick is to use the backing from the typical labels and stickers. You know. The white slick, non stick paper that peel off stickers come on.
I keep a good supply of them in the Shop. When the bleeding stops, put the super glue on the cut, and apply pressure on it with the slick side of the paper. When it is set, slide it off the cut while still applying pressure. The non stick surface will not stick to the glued area, and the pressure will seal the cut. DO NOT putt the paper up and off the cut. It can tear the cut open again. When you slide it off, it will seal, and smooth the would at the same time, while adding a protective layer. In fact, I will sometimes add a couple more layers. (Always use a new area on the paper, other wise it can and will stick.)
Remember the US Air Force developed super glue originally for a sutureless stitch for Air Crew members years ago. And has been sold in Europe for this use for decades.
Being ex-AirForce, I have been using this technique in the Lovett Shop for at least 30+ years.
Does double duty on knuckels that find a grinding belt too.
Never-Ever wear gloves around a drill press, or milling machine. It's a good way to get your fingers pulled off, or wrist broken.
Its' a HUGE no-no!
Mike
Maker
The Loveless Connection Knives
254-865-9956
