Fred.Rowe
- May 2, 2004
Hey Guys,
This is still in the drawing stage, as you can see. I am trying to make up my
mind.
To build or not to build ?????????????????????
I want to forge the guard from, wrought iron.
It makes since to make it in two pieces then fit them together.
I'm planning on putting a twist in the w.i. section that comes down from the handle, behind the ferule, then, intersecting the lower guard. I would like a mortise and tenon joint where the two pieces join.
I plan to inlet the piece into the bottom of the handle, using only one
pin at it's base to attach it.
It would, no doubt, take a bit of fitting up, to get it rite.
Have you seen this guard, made somewhere else?
Should I go, " back to the drawing board" ?????????????
CAN IT BE DONE ?
Fred
mind.
CAN IT BE DONE ?
Fred
