- May 3, 2002
OUCH!: I received a BAD one Monday night. I changed to a less-restrictive bandage tonight so now I can type OK. I was loosening the tightening screw on my Gatco System when the knob broke off and drove my hand into the point of my freshly-sharpened knife. It entered the big meaty heal of my hand at the base of my thumb. The cut was about an inch long and I think about an inch deep. It bled like a quickly dripping water faucet. I closed it reasonably easily with compression. The outside is closing and starting to heal OK - in fact I can touch and press a bit on the flesh without any pain but the inside hurts a lot if I move it too much or strain it so it makes me wonder if I hit a bone or something.
STITCHES: I wonder if I should've gotten stitches? How do you decide? I hate sitting in an emergency room so I'm not likely to go for stitches if at all possible. There's been a few times where I've wondered if I should get them but I never do. When should you really go get stitches? (And don't tell me it lessens scars because I have scars from stitches and some major cuts that left no scar.)
QUEEZY: If I can't close and cover a wound I get within less than 10 minutes (5 min is better) I start to really get queezy. This time I even got queezy and light-headed the next morning when I was only changing the bandage. I actually had to sit down on the toilet and take a break twice so I didn't throw up or pass out. I'm not like that at ALL with OTHER people's wounds and I really wish I could control it when working on my own. It's actually a little shameful and embarrassing thing that I learned about myself a year ago when I got that bad cut at work that I needed help with.
BUTTERFLIES: Maybe I should try to find Butterflies to equip my first aid kit with. I've never seen them in the grocery store. Are they easily found? Someone at work helped me (because I was getting queezy) by applying butterflies one time. Great results!
NASAL SPRAY: A forum member on BF (Gollnick, I think) suggested nasal spray to stop bleeding. I've had mixed results. From my experience it does, indeed, stop bleeding fast but also causes wounds to heal significantly slower and is a bit more likely to leave you with a scar.
BANDAGES: The 3M Nexcare bandages are fantastic! They really stick and stay for as long as you like and they're really comfortable and some come in fancy colors. The various "liquid bandage" products are ok for limited uses - difficult places; but only for minor cuts.
LAST BUT NOT LEAST...
ALCOHOL: No, I don't mean rubbing alcohol... I mean the kind you drink. I drink frequently and half the cuts I receive, I believe, alcohol contributed to me receiving them and MIGHT have been avoided if I hadn't been drinking. I was drinking when the knob broke off my Gatco sharpener. Would it have been different if I wasn't? I don't know, but maybe. I'll probably keep doing it but I gotta warn others that alcohol and knives don't mix. But MOST OF ALL, there is another thing...
Alcohol thins your blood and makes it MUCH harder to stop bleeding. There's been a few times when it's been extra tough for me to close a cut and stop the bleeding because of the alcohol content in my blood, just so you know and aren't surprised when it happens.
CONCLUSION: I wish I didn't cut myself as often as I do. BUT, as often as I handle and 'play' with knives, ODDS are that I'm going to cut myself sometimes. I don't have a problem with that but each time teaches me something and I get a bit more careful. Also, it has a lot to do with me REALLY LEARNING how to sharpen a knife to unbelievably sharp a year ago. I get deep cuts now that would've barely broke the skin two years ago when I didn't know what sharp was. Sometimes I wonder if I shouldn't sharpen my knives so sharp but than I think, "NAAAAAAAHHHH"! : )
Still, I'd like someone to give me the rundown of when someone should go get stitches and when they're not neccessary.
Happy healing.
Happy healing.
