Cutting comp knife- Bladesports qualified
Feedback: +9 / =0 / -0
Up for grabs is my personal cutting comp knife. I used in at Jose's place this summer in the cutting comp and it did well! (my performance was just OK!)
Steel- 5160 about 59 Rc Heat treated by peter's heat treat
Thickness- 1/4
OAL- just under 15"
Blade- just under 10"
Handle- Horse stall mat
Sheath- kydex (currently the sheath is only meant for the competition, it scratches the blade up, but it is meant to be used after all. I can either make one for carry, or one in leather for 25 bucks extra.)
Asking 275 shipped to you. I will be making more of these since it is so much fun to do the cutting comps and they make a great camp knife as well. Next up is .300 5160.
Dan
do they not allow a pointed blade, cause every chopper i see is cleaver shaped
I believe they allow a pointed blade but what use is a point in a cutting comp? These knives are Ferrari's of the knife world. If it doesn't help/have a use lose it.
Dan:
Looks like a high performer - tell me a little about the grind - I can't tell from the photo - is it concave? If so, what radius wheel did you use?
TK
i was thinking from more of a 'dual purpose' [point of view...a capable chopper in 'knife' form, pointed tip and all
I don't think i've seen a .300 thick chopper yet. I've been kicking around the idea of a chopper, very much like the one pictured but with more of a knife design, drop point or nessmuk style tip, angled grip and all, basically the same thing you have here but with more of a knife look to it and slighter exaggeration of the grip heft/pommel.
Have you designed anything similar to what i described above?
It is a full flat grind. I have designed others that are similar but pics/drawings sure help. .300 is what a lot of the guys are using for their choppers. A little more forward weight sure helps. Dan
