- Feb 5, 2005
Gentlemen
May your women appreciate you for being the Studs that you are!
Wow, that is some great info! I really appreciate it.
Let me draw some conclusions and see if I understand what all you fellas are saying.
1. It is likely that in the heat treating process there is enough room for error with either steel that we could negate any advantage one of the steels may have over another?
2. If I could maximize the qualities of the steel, the A2 will be easier to sharpen, will take more abuse lets say in using a baton, and though it is less wear resistance, in the field I am less likely to suffer major damage to the blade? I assume in must cutting situations the A2 will fall behind the D2, but if say cutting bone, or using a baton, it is less likely to break off a significant portion of the blade edge?
3. D2 shines best in the die room wear there is metal on metal, wear as it may fall behind A2 in the field wear you may be using your knife as a bit of a pry tool, or delivering heavy impacts to the back of the blade?
It sounds to me like D2 may not be as stable in a torsional sense, or in taking impacts due to the particle sizes in the steel. Would this imply that it is more brittle?
Thanks so much Guys!!!
AI
AI
