D2 for a camp/chopper
My first thought was somthing like D2 but it's 900° temper is a little lacking. I have not looked at Z-wear but I will. I had thought that CPM-3v would be just about perfect with its 1900° quench and 900-1000° temper. The 1900° quench would set the 17-4 in condition A and harden the 3v. Then the 900° temper would precipitate the 17-4 to around 45-50rc and temper the 3V. I had started down this road once already but quickly relized I needed to start with much thinner 3V and not the big block I have on hand. I'm sure there are quite a few other aloys out there that share the 1900° & 900° treatment. Best bet would be start thin and tig weld the edges and just do a forge weld and not try and draw it out much. If it happened to work you would have a steel that was just about impossible to destroy.
Cru-wear looks to be very simaler in alloy as z-wear with a dash of manganese and silicon. It is probably as perfect of a match as any. Thy list optum hardness with a 1850-1950° quench and a 950° temper which gives around 62-63RC.
Also think about parkerizing or etching. I assume 3V etches a gray color. I've had no success trying to parkerize it. I haven't etched it but ZW is 7.5% Cr too and etches to a dark gray. 4V or M4 are in similar temperature ranges, 4V being closer, with less chromium and might give better contrast.
Chumaman, FFG (does this mean full flat grind) on that blade? Nice looking blade/handle. How thin did you take it. Nice to know it's been done. For his project, I think a new piece of 5160 might be good for him. McMaster had some good prices on bar stock.
yes FFG....Bohler K110 ... Last one - a little lighter :) and acid etched
