D2 Grinding?
I am very seriously considering giving D2 a try on some knives. I am wondering how it compares to say 154CM or ATS34 or for that matter what about against A2 or O1, in terms of grindability? Any input will be greatly appreciated.
I am not talking about anything to do with heat treating as I know that it must be done right, which is why I will send the blades to the master for treatment
C.O.'s-"It takes balls to work behind the walls "
D2 will be a LOT harder to grind than the O1; this much I know for sure. As for the A2, the difference will be less noticable. D2 is also harder to grind than the ATS34 and 154CM. The Vanadium in the D2 makes a big difference.
Danbo, soul brother of Rambo
What DANBO said! Fresh 36,40 or 50 grit belts depending on blade style for roughing and not a lot of fancy grinding prior to heat treat
After heat treat I use 80 grit then 120, 220, fresh 400, worn 400 DONE !! Ready for hand rub. If mirror polishing or finer finish is needed I go through the range or Trizacts from 30 down to 6 on SLOW speed.
Don't BURN your fingers!
Neil
Talonite......Stellite
Hand Made Knives..High Tech Materials
blackwoodknives.com
