Depends what you're cutting and type of media you're using the knives on.
My own observations:
Both knives have 4mm flat ground blades and edge geometry is similar [17-18 degrees per side]. Both finished on Spyderco fine ceramics.
CPM-D2 seems to take a more 'aggressive' edge [subjective, I know] and it eats through cardboard all day long. I call it 'agressive' because after sharpening, it doesn't feel as sharp as it really is to the pad of my thumb. Then I shave hair or cut something with it and I'm amazed at the result. Even after dulling the edge considerably to the point where it won't shave arm hair, it still slices through rough media easily. After sharpening, CPM-D2 pops hairs with less effort than BG-42, but, it won't retain that initial edge for too long.
BG-42 takes a screaming edge and holds that initial hair-popping edge for longer than CPM-D2, even after cutting the same amount of cardboard or other abrasive media. I can go through several large cardboard boxes and it still shaves easily. It'll keep a nice, sharp working edge for months without any major sharpening needed.
Both blade steels work similarly on soft media [vegetables, meats, BBQ
I prefer the longer blade and ergonomics on the Military over the Paramilitary. Maybe a more fair test should be Military vs. Military? Anyone have a spare CPM-D2 one sitting around?
Both knives make excellent slicers because of the edge geometry and grind: not necessarily the steel. An even better slicer would be a 2.5mm thick serrated edge CPM-D2 knife, but for all-around utility work, the 4mm flat ground blade excels because it can be used hard if needed.
While I love BG-42, the CPM-D2 wins for pure slicing ability because it's way more wear resistant. Over the long haul, it'll keep slicing cardboard, food, you name it, while other steels start snagging.
All these observations were gained through using a BG-42 Military for the past 3 years as an EDC knife and a recently acquired [April] CPM-D2 Paramilitary. Purely subjective and it's shameful that I haven't bothered reprofiling these knives to more acute edges. I've been very pleased with the factory bevels - easy to touch up, considering how hard the steel is.
