Soon Im going to order steel to make my first knives. I understand it is not advisable to start with d2 as it is harder to work. But my reason is I can afford to have it heat treated as Texas knife will do it for $6.50 per blade. They dont do oil quench and the best price I found for heat treating oil quench steel is $16.50 per blade. Thats out of my price range for the four knives I want to make for family members. And d2 is quite a bit cheaper then the stainless options. I cant find a2 in the 5/32 x 2 that I need.
That out if the way heres the question. I understand d2 is air hardening. I've read around and the info Ive found says it isn't advisable to reheat treat d2 as it can cause cracking. So once the process is started it has to be finished. So my question is do i need to worry about getting d2 too hot during the cutting/shaping process? Can I cut the rough shape with an angle grinder or do I need to use a hacksaw to avoid overheating? Newb question I know.
If anyone knows where I can get reasonable prices for treating 1095 that would be ideal however. I'm pretty antsy about working the d2 anyway. I have a 1x30 belt grinder and Im not sure the little guy has the oomph. Some people say annealed d2 is slightly harder to work then simple steels and others say its very difficult so I dont know what to believe.
