- Oct 2, 2006
It's my understanding that Bob Dozier does something similar in his D2 heat treat process. This is just my understanding cobbled together from a few things he's said about heat treating D2 in general - YMMV.
Bob Dozier has said that he uses multiple heat cycles, and can get 61 rc w/o cryo. So it seems like it, and it also seems like he is using the high temper. Just speculation of course. I have one of his blades and it performs amazing, also quite tough for D2.
Is this something that could be applied to other stainless steels as well (154cm, 13c26, etc) or does it only work with D2 because it's semi-stainless?
Would it be worth trying on CPM-D2 or would do little since their particle metallurgy already results in a consistent, refined grain structure.
It works for stainless steels too but the temperatures are different. If the initial quench temperature is too high then you get grain growth instead of refinement.
CPM-D2 does not heat treat the same way as D2. If you use the same heat treat for CPM-D2 you end up with something 2 points harder than what you expect from the datasheets. I've never broken any CPM-D2 apart so I don't know how the grain is like.
