In the move to the new shop I rounded up all my past and current projects and have a hand full that I don't have time to finish. I have 4 skinners made from D2 at 61.5RC and thy are all the same design and blade style. All the handle material is professionally stabilized, cant remember by who as I started these a long time ago. The blades are .125 thick and have a blade length of just a hair under 4.5" with a very thin edge that is almost a zero grind. The handle scales are held in place with hidden pins (1/8" hardened steel dowel pins). Its first come first serve, Thanks Guys - JT
blade F.
This blade is almost done, the scales are glued and the handle is shaped and sanded. The blade is hand sanded and for all intents and purposes could get a sheath and a sharpening and be done. I was going to go around the tang once more with a fine belt and blend it into the scales a little better as well as refine the hand sanding. I cant remember off the top of my head what the handle material was
Price is $65 + shipping (small flat rate box)
blade A.
This blade is Identical to blade F except the scales are not glued and the blade is not hand sanded. The scales are shaped and sanded but will need finish sanding after the scales are glued.
Price is $55+ shipping (small flat rate box)
blade D.
This blade also does not have its scales glued and the handle is roughed out. will need some finish shaping and sanding. blade is not hand sanded and handle material is box elder burl.
Price is $50+ shipping (small flat rate box)
blade C
This blade is identical in fit and finish as D but the handle material is Red wood burl.
blade F.
blade A.
blade D.
blade C
