Can you sharpen D2 steel KA-BARS on a regular oilstone? I am finding mixed claims. What is the definitive answer?
Why do people say sharpening D2 is "hard"?? Because that's just not right. The physical skill required to sharpen/reprofile D2 is the exact same amount skill required to sharpen/reprofile 8CR13MOV. It will take (a lot) longer, but it's not harder. That has always confused me![]()
I sharpen D2 on regular stones, and get good results. There seems to be a general opinion that D2 cannot be sharpened period, by anyone, at any time. I don't see what the is sue is.
It may take a little longer if the edge is dull, but it is no where near impossible. Like any steel, if the edge is maintained with routine touch ups, it is just fine. Any sharpening system that works on any steel should work just fine.
The true beauty of D2's edge retention is, stropping accounts for virtually ALL of needed maintenance beyond re-bevelling (so long as you stay ahead of it).
David
Put your strop next to your favorite easy chair and sit back and watch re-runs of NCIS or Baywatch and relax your stress of the day away by stropping your favorite knife back into shape. Then, after you are finished with your blade duties, enjoy a nice adult beverage of your choice. (elevator music in the background.....)
Blessings,
Omar
This last sentience of David's is the basic secrete and answer to nearly any knife steel in use today. If you stay on top of your knives and keep them well maintained (meaning sharpened), your knives will last a lot longer with less blade grinding (loss of blade material). Plus if they are sharp when ever you need to use them, they are much more enjoyable to use and have. If you don't have the time to tune your knife up at the end of each day of use, then get more than one knife to add to your rotation. (horror of horrors, an excuse to buy more knives)
Blessings,
Omar
Funnily enough, D2 isn't all that difficult to sharpen, and polishes up very well.I find D-2 very quick and easy compared to many more modern steels. D-2 is an older steel, but still an excellent blade steel.
If the edge is "chewed up," I start with a coarse diamond on the EP, then a fine diamond, then polish with a 2000 Shapton Pro water stone. Due to the large carbides in D-2, I don't usually go past 2000. But even with a stone that coarse, I can get a light shine, and a good smooth, razor sharp cutting edge with very little toothiness. IOW, an excellent edge.
I don't think that I would enjoy sharpening it with oil stones, though!![]()
