- Jan 9, 2011
well i appreciate your input. The billet was meant for just the blade.
So maybe a good plan of attack. Anneal then cut out the rough shape. Sand/grind one side flat as my reference. Then surface grind the other side. Flip back to the first side and surface grind to final thickness.
I'd anneal it for sure, you can probably get away with a simple anneal cycle... 1500 f then leave steel in kiln to slowly cool. I do wonder if it is soft already or what.
You might want to ream your pivot after heat treat and further straightening, I'd consider leaving some room for straightening/grinding flat again post heat treat.
Keep us updated! That oven looks cool...
