I agree, I believe those inclusions.About half way from plunge is a black line that either an incomplete weld or inclusion. Further towards the tip are a couple more. Someone with more experience and better eyes might explain better.
The pattern is there. It just needs a longer and deeper etch. You also need to sand it more and better.
Will do.. thank you for your help!! Much appreciatedMuch better. Try cleaning it up with some steel wool, washing again, and etching a second hour. I think you have a nice blade there. I don't see any flaws.
Will do.. thank you!!After the second etch, neutralize the etch with boiling in baking soda or TSP.
Then clean it with steel wool. Finally, take some 2000 grit paper and wrap it on a block of hardwood. Lightly work the surface to make the high spots shiny. Done!
Thank you for the advice sir!Looks like a cool pattern and blade, nice job.
The only change I'd make to the above suggestions are to sand to at least 800 grit before etching. IMO, 400 still leaves too many scratches to give a clean, professional looking Damascus blade.
It’s actually for a big fella who wanted it that way.Pattern and welding looks good. The second knife and handle look a bit "fat".
