indian george said:
Bro: The more you fold it the more carbon you are burning off and the pattern will also be affected.
I had to go play with this because I have all this 3/4 inch cable. I think I mentioned that my first effort with the 3/4 inch cable yielded a blade that wouldn't harden but I also know that I got it sparking pretty good a couple of times.
I welded up another piece being more careful. I also used charcoal rather than coal. Call it a technique issue if you want but the coal I had wasn't the best and the fire would quickly go from "clean" to clinker clogged yielding a cold fire one second and a really hot one the next making it hard to to control. No clinkers in the charcoal. Anyway, with this new piece, I stopped welding on it while I still had a piece thick enough to work with. I lopped of a chunk and water quenched and it got extremely hard...no file bite at all. But, I had one section right in the middle that didn't weld completely. I don't think I twisted it enough. ok, I admit that much of this can be attributed to technique issues but with all this F-in around my welding is getting better honest. I went ahead and quickly forged a blade in the hopes that the additional compression would finish the weld. It's a shame because I really liked the way the blade turned out eccept for the open spots in the weld right at the ricosso. I think it would have held together but I knew I wasn't going to like the way it looked. I set it aside in the lessons learned pile (which is getting pretty big) and started over with a new piece of cable.
I twisted it more (maybe not enough still) and was careful not to draw it out too much. I cleaned it up and could clearly see a few spots where the weld wasn't complete. Rather than heat and beat on it some more and risk getting it too small I folded it and rewelded...just just to get more mass. I cleaned it up and it looked completely welded. I cut off a chunk, heated and water quenched and it got glass hard. I went ahead and forged a blade which isn't quit finished yet. Hey, give me a break, it was hot yesterday and I spent WAY too much time in front of the forge.
The bottom line is that I ended up with a thick enough piece to forge a blade out of and, as of the time I started the blade, it was still hardenable. When I finish the blade I'll see what effect it had on the pattern. Again, I concede that there are probably some technique issues here, in that, if I weld small cable it may be too small before I get it completely welded especially if I make sure it doesn't get too hot. A better welder might pull it off but folding it might just work for me. And if it works, I know where there's a bunch of smaller cable that I can get for the asking. If not, using up all this charcoal will get the wood pile gone and make the yard look better and...look at all the welding practice I'm getting!
