- May 21, 2006
I use it mainly for folders.
monty
monty
Bruce,
I'm not sure what you mean. I have one.
Monty, while Brownells says it's for "fast quenching" in their online description, they also say it has a "low rate of heat extraction" to prevent deformation and cracking. It's a mid-speed oil. 1095 needs about the fastest quench you can get, and you have about 1 second or less from when it starts quenching to get the temp below 1000F. That's hard enough to do with the physical manipulation of getting it in the tank, then the quenchant better be fast. In your case, I'd say what you are seeing is exactly where the quenchant ran out of efficacy.
Like others have said, you need a faster oil. You might try heating your Tough Quench up towards 130-140F. Around here the usual oil mentioned for 1095 is Park 50. It's almost as fast as water but a little less brutal on the blade and reduces the possibilty of cracking a bit.
Ive seen those staight lines before on some of my blades except on the flats. It was from using a surface grinder and not annealing afterwards. No amount of regrinding would take them out either. The surface grinder I used even had a coolant system but apparently there is enough heating from hogging off steel to cause some hard/soft problems that only shows up when etching. They go very deep too. I believe you would see them on the flats too if they would have hardened.
Did you happen to grind the bevels with the blade vertical? Even a couple times could have the same effect.
I use tough quench too for 1084/15n20. Great stuff.
1095 needs a faster quench. I use Parks 50. Its super fast but Ive never cracked a blade yet.
Last I would look at the anti scale you applied for heat treating. Did you sprinkle it on or brush it somehow? Was the blade heated in a forge or oven? Did the blade rub up against anything while the compound was liquid covering it? If so you could be looking at streaks of decarb where the atmosphere was able to make contact through the compound.
