- Jun 22, 2010
impresive work congratulatios
Parker, You and Ray are mates? Him and Jan are coming to Walla Walla all the way from Australia at the end of the month. He's bringing some Gidgee? I love that wood! I hope they like Walla Walla sweet onions!So very happy that that piece of wood didn't have a knot in it . You really did it justice Nick. Bruce I'm glad you like Gidgee as my mate Ray has a very special present for you when he catches up with you.
Also thanks for the tip on the True oil trick, that is what the forums is all about.
Cheers
I bought the damascus stud at Tandy Leather Factory...![]()
Just kidding... I made it. I turned it on a lathe, but you don't have to have a lathe to make one.
I used to make finials without a lathe. Here's a quick run-down--- get the side that will be threaded nice and flat, then drill & tap a hole on that side (I used 8-32 which works great and just happens to be what Paul Long wants if you send him a custom stud for a sheath).
Then you can put a long screw or piece of all-thread in the tapped hole (something to hang onto) and rough out your shape with the grinder and/or files. Once you get it somewhat close to being round/symmetrical, you can chuck up the all-thread in a drill. That will allow you to spin the stud against a running belt or disc and make it symmetrical and smooth.
For the inside radius, you can chuck it up in a drill press and use a sharp chainsaw file. To get a nice finish, crank the drill press up to ballz-out, and use sandpaper and shop rolls with a little oil. You'll need to rip the shop roll down to REALLY narrow strips to get into the groove (like 1/8 - 3/16" wide strips).
Don't forget the damascus needs to be hardened to get the best etch out of it.
I'm 99% sure that John White showed how he makes a finial withOUT a lathe in one of his WIPs here, and if I recall correctly, it was pretty similar to what I described above.
Now, if you have a lathe... you can do cool things like make groove cutting bits, radius turning gizmos, or like I did with this stud--- use a 4 jaw chuck and turn a round part from a square bar of damascus.![]()
He is.Adam- so I have a feeling you are to thank for the exhibition grade piece of Ringed Gidgee I got after the issue that came up when I was making Lorien's knife???![]()
