- Dec 11, 2015
I have a gently used Damasko Da37 that im looking to sell or trade. ASKING 850 SHIPPED CONUS TRADES guns ammo holsters other watches knives I have a lot of hobbies can add cash if needed.
Technical Specifications - Model DA37
Movement:
-ETA 2836-2, self-winding, mechanical movement
-25 jewels
-28,800 bph
-Shockproof according to DIN 8308
-Anti-magnetic according to DIN 8309
DA37 functions:
-Hour, minute, permanent central small sweep second
-Day/Date window with new, modified position
-Dial completely coated with non-radioactive luminous compound
Case:
-Stainless steel, nickel-free, bead-blasted
-Ice hardened to 60 HRC or 710 Vickers
-Integrated anti-magnetic inner cage, anti-magnetic to 80,000 A/m or 100 mT
-Sapphire crystal with anti-reflective coating on both sides, AR coating on the underside only, available on special request
-Crystal gasket resistant to UV radiation
-Solid screw back with O-ring Viton gasket
-All gaskets made from Viton which offers a premium chemical resistance and supersedes most other materials used in the watch industry
-Permanent lubrication of crown via lubrication cell
-Screw-down crown with protective shoulders, crown tube screwed into the case for easy maintenance ("System Damasko")
-Crown, stem, and tube hardened to 60 HRC
-Water resistant to 10 bars/100 metres according to DIN 8310
-Crystal has a secure fit even in case of a sudden negative pressure
Dial:
-Dial completely coated with luminous compound LuminovaC1 (white)
-Numbers, hours makers, and triangle at 12 painted in matt black
Hands:
-All hands painted in matt black
Strap:
-Hand made, water resistant, and silicone rubber lined black leather strap
-Bead blasted steel buckle and black Nato strap
Dimensions:
-Case diameter: 40.00 mm
-Overall height: 12.20 mm
-Lug width: 20.00 mm
-Weight without strap: 72 grams
You can email me at Luboo71389@gmail.com or pm me here.
Thanks Sam
Movement:
-25 jewels
-28,800 bph
DA37 functions:
Case:
Dial:
Hands:
Strap:
Dimensions:
Thanks Sam
