Damasko DA46 + a lot of straps $1400
Feedback: +12 / =0 / -0
I bought this from Greg at Watchmann.com back in the fall of 2017. I wore this watch every day for over a year, then two months ago I got a Damasko DSub and that is all I wear. As a result of all that wrist time, there are two things that make the watch not pristine: first, one nick in the Damast coating on the bezel near the tooth by the 30 marker (picture included) - it's not very noticeable due to how the light reflects off the coating; second, the day wheel is ever so slightly out of alignment with the dial cutout - it is noticeable only upon close examination and has no impact on time keeping, and can be adjusted when the watch is serviced next. Otherwise it is very good shape.
Below is from the Watchmann website:
Specs:
-ETA 2836-2
-Self-winding, mechanical movement
-25 jewels
-28,800 bph
-Shockproof according to DIN 8308
-Anti-magnetic according to DIN 8309
Case:
-Stainless steel, bead-blasted, nickel-free, finished with extremely abrasion-proof Damest layer
-Ice-hardened to 60 HRC or 710 HV, fully hardened
-Integrated anti-magnetic inner cage, anti-magnetic to 80,000 A/m or 100 mT
-Sapphire crystal with anti-reflective coating on both sides, AR coating on the underside only: available at special request
-Crystal gasket resistant to UV radiation
-Solid screw back with O-ring Viton gasket
-Gaskets of crown with permanent lubrication
-Gaskets made of Viton offering premium chemical resistance
-Screw-down crown with protective shoulders, crown mechanically hardened – nearly indestructible
-Crown barrel screwed into case according to “System Damasko” – absolutely easy to service
-Bi-directional rotating bezel with exact minute engagement on ceramic bearing,
patented mechanics
-Protected from the intrusion of dust by gasket element
-Hardened, PVD-coated and scratchproof bezel insert
-Two optional bezel inserts: 60-minute or 12-hour ring (according to US
military specifications)
-Water resistant according to DIN 8310, pressure-proof up to 10 bar/100 metres
-Crystal with secure fit also under negative pressure
Dial:
-Matt black, hour markers and triangle at 12 provided with a persistent special paint
Hands:
-The hour and minute hands are painted black and provided with a white, persistent special paint
-The second hand is painted black and coated with signal yellow special paint
Strap and bracelet:
-Leather and rubber-lined black leather strap with bead-blasted buckle
Dimensions and weights:
-Diameter: 40 mm
-Overall height: 12.40 mm
-Bezel diameter: 41.90 mm
-Lug width: 20 mm
-Weight: 90grams
The watch still keeps great time, usually within 10 seconds a day when worn regularly, tending towards the fast side. The bezel action is very precise - probably one of the most fun bezels to play with. The crown is amazing to use, the disconnect when screwing/unscrewing is silky smooth and makes adjustments very easy.
Comes with the original Damasko box, owners booklet, Damasko branded leather and rubber strap, 10 nylon straps - mostly ToxicZulu's, an Erika's Original Strap sized for a 7.5 inch wrist in green with yellow center stripe, and a whole gaggle of 20mm spring bars.
I am not interested in trades of any kind.
$Withdrawn Paypal G&S will get it shipped with tracking number and signature at time of delivery
