I need to start out by declaring my ignorance with all things stainless so I cannot address any of those issues. But the topic of plasticity above Ms has been brought up, and this I am very familiar with. One of the great advantages of an interrupted quench (marquenching/martempering) is the ability to straighten any kinks that may have occurred in the initial quenching process. This is easily done with salts (as I do) or with interruption of an oil quench.
Have a good pair of gloves on before the quench, at a point above 400F.(depending upon the alloy), but not too much above, interrupt the cooling process. In oil this will be about right if the sizzling has stopped and there is oil covering the blade but a few wisps of light vapor or smoke coming off. At this point the blade will have avoided the pearlite nose entirely but will not have formed martensite yet, it will be in a stage of very unstable austenite (which means it is also very bendable). Quickly eyeball it straight, using your gloved hands to tweak it. Be very careful as the blade is the same structure as it is at forging temp., so you could easily over bend it (I have even left finger dents at the edge from holding it too tightly when tweaking).
Mete is correct that you will not have all day to do this, but you should have more than enough time to work it straight. The time depends upon the alloy. 1095 blades have to be done real quickly, while I have worked L6 blades for as long as 8 minutes before.
If you still miss some minor warpage, they can also be tweaked at a 400F. tempering temperature, but it will take a lot more force and you need to be a little more careful. If it is a single edge blade, and you still have a kink that you cannot get, put one end in a vice and hold some wet ceramic wool against the edge to protect it while you heat the spine until it is blue. While it is at this temperature it will get very receptive to adjustment again and you can get just about any kink out, and not worry about breaking it unless it cools again while trying.
One note about the interrupted oil quench, be careful not to interrupt at too high a temp. If the edge drops below Ms and the spine is still 600F. when you remove the cooling action, that heat is going to bleed down to the edge and start tempering your fresh martensite at 600F. This form of quenching will produce a blade with significantly more impact strength due to the fact that the martensite literally has not time to develop stresses before it has a quick snap temper from the slow cooling process. Many people have noticed a 2-point drop in Rockwell hardness from this method and then wrongly concluded that they had lost overall hardness from it. WRONG! In the big picture you have achieved the same hardness, you just got a jump-start on the tempering process. I must also stress that you must temper after this quench like any other hardening operation. I prefer to use the term "marquench" because too many folks get the idea that they don't have to temper because it is called "martempering".
