Parkerizing is an easy finish to do on carbon steel, it won't work at all on stainless. You just heat the parkerizing solution to 180 - 190 degrees (in a stainless container, old pans work fine) insert clean, abrasive blasted, and grease free steel, wait 10-15 minutes and you're done! It holds a nice coat of oil against the blade and is very durable. Probably not the most attactive finish though and it does add a little thickness to the blade, not much though. I recently used it on my first folder blade, mostly because I used O1 for the blade and it was the easiest way to protect the blade for me to do (I already had the solution).
You can order the solution from Brownell's, or look in Shotgun News, lots of people sell it.
Patrick
PS - Do not do this indoors! Do not breath the fumes! Wear Gloves! Also, Harbor Freight sell a powder coat gun and a limited selection of coating colors, pretty cheap too.
