Andersonbushcraft
- Jun 14, 2019
Hey all,
How does the dark grey surface patina from a ferric chloride etch holdup/compare to something like a black oxide for darkening Carbon Steel? Looking for something that is not a coating that will chip off, but a controlled forced patina that is black or dark grey.
I want to try out a new user finish on some woods knives out of 8670 steel. I normally make a user finish by grinding to 120-220 then running it through the scotchbrite grits for a satin finish that tends to hid light scratches and wear a bit more than a 600 grit belt/handsand satin, but I want to darken the steel and add some mild corrosion resistance to it since the handle scales will only be attached with flared tubing.
I was thinking of trying either a bead blast followed by black oxide at peters after a heat treat or a dip in ferric chloride after they come back on a 120 grit scotchbrited finish. Probably a light coat of BLO to add some protection under the scales.
I've tried cold blue on a 120 sb before and it turned out pretty good for a working finish, but I honestly cant stand the smell and want a finish that could be used on food if needed.
Thanks in advance!
Thanks in advance!
