- Sep 12, 2013
Custom made Friction Folder. Razor sharp chisel tanto grind using heat treated 1084 steel. Blade is acid stone washed with a satin finish on blade grind. The opening lever features a flat head driver so you wont have to use the blades tip in those uncalled situations. Tough pivot bolt, oxide hardware, and stainless steel standoffs for easy cleaningg. Florescent green & black G10 handles with a grippy Z pattern that nicely conforms to your finger grooves. Knife feels amazing and very safe in the hand. I can make a custom pocket clip in tip up carry for no additional charge if buyer is interested. Lifetime Warranty
Price is SOLD within USA
MATERIAL
Blade: 1084 Steel (High Carbon Steel)
Handle : Neon Toxic Green & Black G10
DIMENSION
Blade Length: 2.10"
Blade Thickness: .20"
Cutting Edge Length: 1.85"
Handle / Scale Length: 3.30"
Overall Length: 5.40"
Lever Length: 1"
Overall Length with Lever: 6.40"
WEIGHT
4.075 Ounces (115.6 Grams)
