- Oct 4, 2011
From what I know:
-DC motors can run from any speed from zero to max, but torque is dependent on RPM?
-AC motors can run from 1/3 is rated RPM to max, but has constant torque throughout the speeds.
What other differences are there? Reliability? Noise? "Smoothness"?
If buying new, I can get a set-up for either around 1.5hp or 2hp for about the same price; I've noticed that 3ph motors can be found cheaper, but the VFD's are generally more expensive that DC speed control counterparts. If I go used an AC set-up will almost probably definitely maybe be less expensive.
From your experiences, which do you like more? What issues have you had with either?
Thanks guys
(I've done searching and researching for a while now, but haven't quite found the answers I'm looking for here)
Off-topic, I think this grinder is GOOOOOOD LOOOOKIN.
Thanks guys
