1) Brand new DDC BBn-L (SMF) folder with all the papers. stickers, case, etc. It has a Magnesium and a titanium handle... and a Nitinol (SM-100), which is completely corrosion proof, blade. Perfect action, lock up, and centering. I am the first owner, never carried it, never used it.
Here are quick pics of it:
Here is an official description of this piece:
About the BBN-L: Basically, Duane's BBN-L is like a SMF with a "bobtail" end. So, it is familiar as the SMF we all know and love, and yet has an entirely new feel. It is not like a ton of material has been actually removed but that tiny dimensional change makes the knife feel smaller in the hand. Reverse grip is also enhanced. While in your pocket, it is easier to get your hand in that pocket to get at your other stuff.
The Blade: Hand double hollow ground Pike profile from SM-100. One of the cool side effects of SM-100 is the incredible colors that can appear as a result of the heat-treating process. These can be blasted off, but because the look so cool, Duane leaves them. No jimping grooves on spine for clean look.
The Frame: Titanium lock side has bronze thermally colored finish with orange peel texture on flats and blasted matte finish in ball cuts. Hand flamed 'Lightning Strike" details on lock side. All upgraded titanium hardware (Duane's new pivot, screws, etc.) with bronze/gold anodized finish. Non-lock side is made from ultralight Magnesium with double radial texture, Dow 7 pale gold colored finish and has periodic table engraving. In addition to being super light, the Magnesium side can be used as a fire starter, adding some extra function to the knife. Both sides have been ball milled giving both increased grip and looks that kill. Pocket clip can be configured for either left or right-hand carry.
Benefits of SM-100 Material:
Corrosion proof - SM-100 is completely non-ferrous (meaning zero iron). It cannot rust. It does not know how. This does not mean rust resistant, it means corrosion proof as defined by NASA.
Nonmagnetic - While this does not mean much to most folks, those in the ordinance world sure appreciate it.
Edge Retention - SM-100 can be hardened to >60 Rockwell. In addition, this hardness goes all the way through the material (you can mill off 10 thou and test each layer). In the past, you could get titanium sharp, but it would lose its edge quickly. Now, with SM-100 you essentially get a hardinable titanium.
Lightweight: SM-100 is almost 20% lighter than most steels per given size.
Toughness: Due to its high Modell number (measure of wear resistance) and its elasticity, SM-100 is extremely resistant to shock damage. So, while being rust proof, longer lasting, and lighter, SM-100 also is ready for true hard use.
Yours for $1875 (net) shipped in the US. Sorry no trades on this.
2) Brand new DDC BBN-S (PT) Pike folder with carbon fiber and DLC titanium CC handle and a PD-1 blade; comes with a leather lanyard, its sticker, card, case, etc. It has a perfect action, lock up, and centering. It is a small folder but the double hollow grind PD-1 blade is ready for action. I am the first owner, never carried it, never used it.
It is yours for $975 (net) shipped in the US.
Sorry, NO TRADES on these. Thank you for your time...
Please see the next post for pics BBN-S.
About the BBN-S: Again, Duane's BBN-S is like a PT with a "bobtail" end. So, it is familiar as the PT we all know and love, and yet has an entirely new feel. Just like the other piece, it feels smaller in the hand with an enhanced reverse grip.
The Blade: Duane hand double hollow ground a wicked Pike profile from super tough PD#1 with military grade black oxide finish.
The Frame: Carbon fiber non lock side and titanium lock side with black DLC finish. All of the titanium hardware (frame screws, pivot) have natural Ti finish. Both sides of the frame have been contoured, printing less in your pocket and making of and all around more comfortable knife to hold. Leather lanyard included.
About Carpenter PD-1 Steel: It all started years ago with VascoWear manufactured by Teledyne Vasco which was an incredibly tough alloy. Crucible Steel then later came out with their version called Cru Wear (slightly different formula). With the advent of the powdered metal process, Crucible then applied this superior process and further tweaking the mix to create CPM 3V (which we all know and love). Fast forward to now and Carpenter Steel has gone back to the original VascoWear formula and updated it and applied their modern Micro-Melt powder metal process to it to create PD-1. Duane says PD-1 is supposed to be very comparable to the CPM 3V with the difference being the carbides. It is supposedly the same toughness and maybe a BIT better in wear resistance than 3V. Again, not a stainless, so corrosion resistance is also on par with 3V.
Specifications
Specifications
- Overall Length: 6.5 in
- Blade Length: 2.875 in
- Cutting Edge Length: 2.25 in
- Blade Thickness: .125 in
- Weight: 2.2 oz
- Blade Material: PD#1
- Handle Material: Titanium/Carbon Fiber
- Included:
- Padded case
- Spec card
- Sticker
