DDC BBN-L (SMF) Strider with Mg handle and Nitinol blade
Altan
Feedback: +58 / =0 / -0
Brand new DDC BBN-L (SMF) folder with all the papers. stickers, case, etc. It has a Magnesium and a titanium handle... and a Nitinol (SM-100), which is completely corrosion proof, blade. Perfect action, lock up, and centering. I am the first owner, never carried it, never used it.
Here are quick pics of it:
Here is an official description of this piece:
About the BBN-L: Basically, Duane's BBN-L is like a SMF with a "bobtail" end. So, it is familiar as the SMF we all know and love, and yet has an entirely new feel. It is not like a ton of material has been actually removed but that tiny dimensional change makes the knife feel smaller in the hand. Reverse grip is also enhanced. While in your pocket, it is easier to get your hand in that pocket to get at your other stuff.
The Blade: Hand double hollow ground Pike profile from SM-100. One of the cool side effects of SM-100 is the incredible colors that can appear as a result of the heat-treating process. These can be blasted off, but because the look so cool, Duane leaves them. No jimping grooves on spine for clean look.
The Frame: Titanium lock side has bronze thermally colored finish with orange peel texture on flats and blasted matte finish in ball cuts. Hand flamed 'Lightning Strike" details on lock side. All upgraded titanium hardware (Duane's new pivot, screws, etc.) with bronze/gold anodized finish. Non-lock side is made from ultralight Magnesium with double radial texture, Dow 7 pale gold colored finish and has periodic table engraving. In addition to being super light, the Magnesium side can be used as a fire starter, adding some extra function to the knife. Both sides have been ball milled giving both increased grip and looks that kill. Pocket clip can be configured for either left or right-hand carry.
Benefits of SM-100 Material:
Corrosion proof - SM-100 is completely non-ferrous (meaning zero iron). It cannot rust. It does not know how. This does not mean rust resistant, it means corrosion proof as defined by NASA.
Nonmagnetic - While this does not mean much to most folks, those in the ordinance world sure appreciate it.
Edge Retention - SM-100 can be hardened to >60 Rockwell. In addition, this hardness goes all the way through the material (you can mill off 10 thou and test each layer). In the past, you could get titanium sharp, but it would lose its edge quickly. Now, with SM-100 you essentially get a hardinable titanium.
Lightweight: SM-100 is almost 20% lighter than most steels per given size.
Toughness: Due to its high Modell number (measure of wear resistance) and its elasticity, SM-100 is extremely resistant to shock damage. So, while being rust proof, longer lasting, and lighter, SM-100 also is ready for true hard use.
Yours for $1550/net (OBO) shipped in the US. Sorry no trades on this.
Thank you for your time…
