According to verhoeven, a carbon atom can move 1mm in 18 min at 2100f. At 1700-1800f, it's about an hour, plus or minus a few minutes.
That's a good point. When I say decarb, I'm referring to the soft layer of material that always exists after heat treat, usually .005" to .020" thick depending on material, temp, time, etc. I'm using satanite wash to reduce scaling, not necessarily decarb, although I imagine it does help with that.
If carbon moved out of the blade as fast as some think, forging wouldn't be possible.
Different steels decarb at different rates. I've never seen it go more than a few thousandths of an inch. Might be more in an oxigen rich atmosphere.
Hoss
I get almost zero scale unless I am forging at high heat or welding Damascus.
I get virtually no scale during normalization Cycles. If you're getting lots of scale things need to be adjusted.
While in an extreme situation, there might be .005" of secarb, .020" would be nearly impossible unless the steel was placed in a high temperature oven for days. 020" is 500 microns.
I was about to say the same thing, Karl.
Mr. Ken Tucky... how long are you soaking at your normalizing temps?
Thank you for pointing out those numbers. Let's be certain to mention that for carbon to move and migrate at those rates it must first have a place TO GO.
That is why I often use the de-carb line in stainless/carbon san-mai as a carbon migration example. The carbon is moving from a carbon Rich environment to a carbon deficient environment. When you have a homogenous piece of Steel the carbon has no Need to go anywhere.
If our carbon was leaving our steel at the rate mentioned then in just any normal forging situation we would not have any carbon left in our Steel.
The 1095 I have is hot rolled plate and it comes in at 45 RC. I anneal it before working with it by soaking at an hour (stacked blade blanks) at 1600F and then shutting the furnace down and letting it cool overnight. When I pull them out the next day they're usually still 250F or so, so they cooled at roughly 100 degrees an hour. In that state they're right around 20 RC. After rough machining or grinding, I normalize 3x, 1600, 1500, and 1400. I austentize at 1475 for 10 minutes, quench in Parks 50 and at that point expected to see 66 RC. I had to grind .020 to see 66 RC consistently throughout the blade. Surface ground, I didn't mic the thickness, so while I dialed .020 wheel wear etc maybe I took .018".
That's where I get the .020". At .010" the RC would swing from high 40s to low 60s. I didn't test again between .010" and .020" I just went another .010" to make sure since the hardness tester is on the other side of the plant from the surface grinder.
ETA: no wrap, no clay, no atmospheric control
I'm getting about 0.010" of decarb with normalizing and heat treat.
