- Dec 19, 2002
Ryan Roberts Design "DeathGrips", Fits Benchmade Mini Griptilian
Our Price: $94.95
http://www.knifeworks.com/ryanrobertsdesigndeathgripsfitsbenchmademinigriptilian.aspx
Blue and Black G-10 replacement scales for Mini Griptilians. Replaces... plastic handles for the look and feel of more expensive knives. These scales are CNCd and made to the same tolerance level as BM to ensure a perfect fit. G10 is a woven glass epoxy laminate, it is a common handle material for many high end knives because of it's high strength, durability and wear resistance. These scales are CNC machined for a perfect fit, then bead blasted for a textured finish to provide more grip. Converts Griptilian to flow through style back with included barrel spacers for easy cleaning. All necessary hardware is included.
These are off pre-order! These will start shipping this Fri. 3/28.
So, about (30) of this Sprint run are available now!
This looks to be the most sought after of all the Super Blue Sprints this year!
Spyderco Stretch SPRINT RUN Folder, Super Blue, Gray FRN
Suggested Retail: $174.95 Our Price: $106.95 You Save: $68.00
Free USA shipping on all orders over $99.00
http://www.knifeworks.com/spydercostretchsprintrunfoldersuperbluegrayfrnhandle.aspx
The Spyderco Stretch has changed over the years much like watching... one of your kids grow up. What started as a small basic Hunter model in the 1980s matured/stretched into an elegant high performance drop point folder available in a variety of handle materials and blade steels. The latest is a sprint run lightweight model with a gray FRN (fiberglass reinforced nylon) handle.
Spyderco's Sprint Run Stretch is made with Aogami Super Blue steel. Aogami Super Blue is produced exclusively by Hitachi Metals at their plant in the Shimane Prefecture, Japan. They use high quality iron-sand found only in this region to create different grades of steels including white steels and blue steels. The steel itself isn't blue or white in color but the designation refers instead to the color paper the raw steel comes wrapped in when delivered to Hitachi. In Japan its common practice for steels to be named and referred to; based on the color of the packaging the raw steel is delivered in. Super Blue is the highest grade blue steel and contains up to 1.5% carbon for wear resistance and chrome to elevate hardness and improve edge holding and corrosion resistance.
The gray fiberglass reinforced nylon handle features Spyderco's patented Bi-Directional Texturing for slip-free tactile traction. Inside the handle are dual skeletonized stainless steel liners which strengthen the knife without additional weight and double as an anchor for external and internal components to attach through generating more sturdiness and rigidity. The knife locks up solidly with a mid-positioned back-lock with a four-way tip-up, tip-down, left- or right-handed hourglass pocket clip.
Sprint Runs
A Spyderco Sprint Run is defined as a limited edition production of any Spyderco product in a configuration different than what has been previously produced. It can include changes in the handle color, materials, blade steel, coatings, etc. The quantity of each Sprint Run is generally 600 or 1,200 pieces, which is determined by Spyderco.
Specifications:
Overall Length: 7.94"
Blade Length: 3.50"
Cutting Edge: 3.19"
Blade Thickness: 0.125"
Blade Material: Aogami Super Blue
Blade Style: Modified Drop Point
Blade Grind: Flat
Blade Finish: Satin
Edge Type: Plain
Handle Length: 4.44"
Handle Thickness: 0.422"
Handle Material: FRN
Handle Color: Gray
Weight: 3.4 oz.
Pocket Clip: Right/Left Hand, Tip-Up/Down
Knife Type: Manual
Opener: Thumb Hole
Lock Type: Lock Back
Brand: Spyderco
Model: C90FPGYE
Our Price: $94.95
Sprint Runs
Specifications:
Blade Length: 3.50"
Cutting Edge: 3.19"
Blade Grind: Flat
Blade Finish: Satin
Edge Type: Plain
Handle Color: Gray
Weight: 3.4 oz.
Knife Type: Manual
Opener: Thumb Hole
Brand: Spyderco
Model: C90FPGYE
