Jason B.
- Jun 13, 2007
I just got my mind blown. I thought that shaving hair off my arm wouldn't happen below 600 grit somehow. I can't remember where I got this silly idea from.
Do I need to deburr aggressively first, or this is going to work even if some burr is left?
Do you have other tests after coarse stones to tell 'your apex is ready'? Catching on the nail?
P.S. So the burr I felt would've been from the previous sharpening? Or burr occurs even if not fully apexed? (I think I saw that in another thread - but my memory sucks - sorry for asking again)
Coarse stones produce more burr which is harder to remove but as with ANY STONE you use light pressure and you will reduce the burr size. With minimal burr on the edge from even a 100 grit stone you should still be able to pass simple tests.
If you create an apex it will typically be noticed by the full length burr created at the edge. It should show up and be "moved" from one side to the other as you switch sharpening sides. If this happens it a good indication you have reached an apex.
My "test" is always visual inspection, I look at the edge closely and under bright light looking for defect in the scratch pattern, burrs, and angle consistency.
